Ходих до един уж читав сервиз в Борово и от каталога ми казаха, че в скоростната кутия се налива двигателно масло.
Това малко се стресира - дали наистина е така?
Невероятно но факт. На моето 940 го сменях преди месец в сервиз "Друмник". Като ми казаха, че са сложили двигателно масло в скоростите изтръпнах. Оказва се, че има скоростни кутии който ползват такова масло.
Това е от ръководството за експлоатация:
1996 Volvo 850
Oil quality
Meeting API specification SG, SG/CD, SH or Energy Conserving (EC) II
For best fuel economy and engine protection, consult with your authorized Volvo retailer for recommended oils. Oil with a different quality rating may not provide adequate engine protection. Synthetic oils complying with oil quality requirements are recommended. Volvo recommends the use of fuel economy improving oils. Look for the API label.
Synthetic oils complying with oil quality requirements are recommended for: Driving in areas of sustained temperature extremes (hot or cold), when towing a trailer over long distances or for prolonged driving in mountainous areas.
Extra oil additives must not be used unless advised by an authorized Volvo retailer.
Engine oil Quality: Meeting API specification SG or SH Capacity (incl. filter): 850 (5-cyl. engine) 5.6 US qts./5.3 liters (certain models: 6.1 US qts./5.8 liters)
850 Turbo - 5.6 US qts. (5.3 liters)*
Automatic transmission fluid Quality: ATF Dexron IIE/ III and Mercon Capacity: 8 US qts. (7.6 liters)
Manual transmission fluid Quality: Volvo synthetic gearbox oil 1161423 Capacity: 2.2 US qts (2.1 liters)
Power steering fluid Quality: ATF Capacity: 0.85 US qts. (0.8 liters)
Brake fluid Quality: DOT 4+ Capacity: 0.64 US qts. (0.6 liters)
All specifications are subject to change without notice.
* Add 0.95 qts. (0.9 liters) if the oil cooler has been drained Capacity: 8 US qts (7.6 liters)
Viscosity (stable ambient temperatures):
1996 Volvo 850
Oil quality
spiritus Wrote:Здравейте,
...... че в скоростната кутия се налива двигателно масло.
Абсолютно ! Има кутии , чиито лагери и з.колелета са констуирани за двигателно масло!!! :roll: :!:
А има ли някаква пробка или нещо подобно (и къде е) от която мога да проверя нивото на маслото в скоростната кутия?
