Threads: 12
Thanks Received:
0 in 0 posts
Thanks Given: 2
14
Горд собственик на: XC90 V8 Executive'06
За да не светят фаровете при положение 0 на ключа, може да се програмират с VIDA...аз го направих така и сработи от раз:
How to disable Daytime Running Lights on a Volvo XC90:
• Launch VIDA and connect DiCE unit. Verify vehicle specifics.
• Navigate to the main “Diagnostics” tab.
• Click the “Vehicle Communication” tab that results.
• You will be presented with a diagram of all of the modules that are active in your vehicle, as seen in the image above.
• The green blobs are the different modules in the car; click on them to see what they do. Note that in your vehicle your modules may not be green. This is not necessarily cause for alarm. Certain modules will log a fault which will change the color of that module. The modules tend to end in the letter “M” for module. CEM is Central Electronics Module. BCM is Body Control Module. TCM is Transmission Control Module. These are all of the modules that the dealership will ask you to upgrade when you come in for an oil change
• Click on the CEM module inside the vehicle diagram.
• On the bottom half of the screen you will see a set of tabs. Click on “Advanced”.
• Click the + symbol to expand all of the CEM options.
• Select “programming control module”.
• Select the option for Daytime Running Lights (DRL).
• At this point a page with a lot of details should load. Link with details for DRL configuration
• Click on the “VCT2000” image on the left to begin programming your CEM.
• If your goal is to turn off the DRLs, set the “CEM – Daytime running lights” to “Flexstd”
• Click “Start Programming”. It was instantaneous.
Виж с премахването на алармата за непоставен шофьорски колан и автоматично заключване на вратите след потегляне не можах да се справя с четене в нета, та ако някой може да помогне къде и какво да се пипне с VIDA нека да пише :roll:
бай Вълчо си харчи, но като за "малка ГАЗ-ка" не е толкова страшно, а и ти пълни душата на
MAX ...до тук толкова - цък >>
