10-31-2006, 01:03 PM
здравейте колеги... интересуваме дали може някой да даде инструкций как се инсталира вадис-а?
10-31-2006, 05:36 PM
дано си си дръпнал английска версия, щото масово са шведска и словенска (голям зор докато намеря EN)
Installation instructions
Activation code DMQKF-RXTBV-FD98H-462TB-TC9FG. May not be needed.
Reboot computer and set date to June 2004(2005A) or March 2003 (2003F). The Vadis program has an expiry date, so resetting the computers date before using Vadis places the machine before this expiry date.
Scan dvd before hand so you know it is virus free. Shutdown virus software.
If autostart does not work browse dvd and run dos batch file SETUP.BAT
Pick customised setup and select all components. Than press next.
Install will now start. This takes quite a while so please be patient.
Restart machine.
Remember to reset date. Now run Vadis.
User is sysadm
Password is NQZ5-XC3E-P8HD-A2SU
Next click system configuration which allows you to create your own user name and password
Enter your own user name and password.
Select all information and international misc in partner group
Press CREATE NEW USER and then click ok.
Log back into Vadis using your own user name and password.
Press information manager and enter your cars vin number. Car can be selected by model number, engine etc but vin number is far quicker.
Then select right or left hand drive. Then body style. S.R is sunroof.
Some options try to talk to the car, so unless you have the correct tool these options will not work.
Any questions just ask I will try to help.
Questions
Q: Where is my dvd?
A: The only answer I can give is it is in the post as posting to America and Canada takes 2-4 weeks. There is no tracking number and a proof of posting is always obtained
Q: Where is the user name and password.
A: In the Vadis set up instructions.rtf on the dvd and above
Q: My virus scanner warns of a malicious script
A: Turn off Norton
Q: I get error code umb0008 cannot access the security database
A: Press system configuration not user configuration when entering admin password
To help fix any problems
The password must be entered with dashs
Date was set to June 2004 through out installation and running program
Over 4gbs of free space on c drive before installing vadis
C/info folder has 3 folders in it vv126526, vv126527 and vvindex. Total size on hard disc for all three 3.44gb
The info folder on the dvd should also have three folders and be the same size
Copying all the info folders manually onto the hard drive after installing vadis
Have you tried removing all of vadis via add/remove programs. Removing the c/info folder manually. Then reinstalling the complete dvd. While installing the data it should list the three folders mentioned above with no warning signs besides them and as each is finished its ticked.
Copy the contents of the entire DVD to a separate directory and install from there
If you get eg this series of errors when starting installation
after putting DVD into player:
[DVD-drive]:\Scripts\IE60Xml\IE60Xml.vbs
Line: 13
Char:1
Error: ActiveX component can´t create object:
'Scripting.FileSystemObject'
Code: 800A01AD
Source: Microsoft VBScript runtime error
this follows:
Can not install UserGuide. There is no cdinfo.txt found!
and after that you should cancel whole installation
process or you get this error:
Windows Script Host
[DVD-drive]:\Sripts\Lan\VadisUpgrade.vbs
Line: 10
Char:1
Error: Could not locate automation class names
Code: 80020009
Source: Wscript.CreateObject
Somehow WindowsXP SP2 disables these DLLs from computer
and only thing to do to fix the problem is:
1) Open command prompt
2) Go to C:\Windows\System32 diretory
3) Run command: regsvr32 scrrun.dll
4) Popup message should say that registerin was completed succesfully
What is this file?
Scrrun.dll belongs to operating system and this scripting
error is well know by programmers nowadays.
DLL File: scrrun or scrrun.dll
DLL Name: Microsoft Script Runtime
Restart machine.
User is sysadm
Questions
Q: Where is my dvd?
A: Turn off Norton
Line: 13
Char:1
Code: 800A01AD
this follows:
Windows Script Host
Line: 10
Char:1
Code: 80020009
What is this file?
Restart machine.
User is sysadm
Questions
Q: Where is my dvd?
A: Turn off Norton
Line: 13
Char:1
Code: 800A01AD
this follows:
Windows Script Host
Line: 10
Char:1
Code: 80020009
What is this file?
Restart machine.
User is sysadm
Questions
Q: Where is my dvd?
A: Turn off Norton
Line: 13
Char:1
Code: 800A01AD
this follows:
Windows Script Host
Line: 10
Char:1
Code: 80020009
What is this file?
10-31-2006, 06:17 PM
В събота закупих VOLVO VADIS 2006 и до 1-2 дни очаквам да ми доставят дисковете. Като се пробвам с инсталацията ще пиша кое как е и що е.
10-31-2006, 06:45 PM
мерси за подробното описание ама питах за версията която е от волво фен... сега свалям някъв вадис 2003Д.... тук от форума взех линка ..ще го побвам и него :?
