03-18-2008, 12:10 PM
Pages: 1 2
някой знае ли как се сваля цялата предна броня? Моля за помощ..
03-18-2008, 12:46 PM
дано това ти помогне
03-18-2008, 12:49 PM
И заедно със снимките на Cavalera - и това:
Removing and installing front bumpers
Removing the front bumper
-Applies only to B4194T or B4204T engines: Remove the covers over the right and left headlamps
-Remove the turn signal lamp bulbs on the left and right-hand sides
-Remove screw A and the right and left retaining clips for the mudguard
-Remove the cable clip B on the front bumper.
If applicable:
-Disconnect the connectors for the outside temperature sensor, horn and headlamp wipers
-Disconnect the washer hose for the headlamp wipers at the T-junction.
-Remove the front engine cover under the engine. Disconnect the connectors for the sidemarker lamps.
If applicable:
-Disconnect the connectors for the fog lamps.
Note! If a parking heater is installed, disconnect the power supply connection at the air cleaner (ACL) and disconnect the ground lead for the parking heater.
-Remove the 2 clips (A) from the front bumper
-Remove the 4 mounting screws for the bumper.
If applicable:
-Fold the headlamp wiper arms forward.
Remove the front bumper assembly.
Installing the front bumper
If applicable:
-Install the front bumper
-Install the 2 clips (A) for the front bumper
-Install the 4 mounting screws for the front bumper. Tighten to 40 Nm.
-Connect the connectors for the sidemarker lamps
-Connect the connectors for the fog lamps if applicable
-Install the front engine splash guard under the engine.
Note! If a parking heater is installed, connect the power supply connector at the air cleaner (ACL) and connect the ground lead for the parking heater.
-Install screw A and the right and left retaining clips for the mudguard
-Connect the connectors for the outside temperature sensor, horn and headlamp wipers
-Connect the connectors for the turn signal lamps. Reinstall the turn signal lamps
-Install the covers over the right and left headlamps.
If applicable:
If applicable:
If applicable:
If applicable:
If applicable:
If applicable:
If applicable:
If applicable:
If applicable:
If applicable:
If applicable:
If applicable:
03-18-2008, 08:17 PM
Mного благодаря :roll:
няма да се размине махането на фаровете явно... тея болтове не се стигат
04-10-2008, 10:12 AM
А можете ли да извадите такава картинка за демонтаж и за задната броня?
Между другото - с помощта на тая тема свалих предната броня за 5 минути, без да махам нищо друго
Pages: 1 2
