Нещо интересно изпратено ми от мой познат - Printable Version +- Волво Клуб - България (https://volvoclub-bg.com/forum) +-- Forum: Общ форум (https://volvoclub-bg.com/forum/forumdisplay.php?fid=4) +--- Forum: На лафче (https://volvoclub-bg.com/forum/forumdisplay.php?fid=25) +--- Thread: Нещо интересно изпратено ми от мой познат (/showthread.php?tid=721) Pages:
1
2
Нещо интересно изпратено ми от мой познат - хамлет - 07-27-2006 The Red Planet is about to be spectacular! This month and next, Earth is catching up with Mars in an encounter that will culminate in the closest approach between the two planets in recorded history. The next time Mars may come this close is in 2287. Due to the way Jupiter's gravity tugs on Mars and perturbs its orbit, astronomers can only be certain that Mars has not come this close to Earth in the Last 5,000 years, but it may be as long as 60,000 years before it happens again. The encounter will culminate on August 27th when Mars comes to within 34,649,589 miles of Earth and will be (next to the moon) the brightest object in the night sky. It will attain a magnitude of -2.9 and will appear 25.11 arc seconds wide. At a modest 75-power magnification Mars will look as large as the full moon to the naked eye. Mars will be easy to spot. At the beginning of August it will rise in the east at 10p.m. and reach its azimuth at about 3 a.m. By the end of August when the two planets are closest, Mars will rise at nightfall and reach its highest point in the sky at 12:30a.m. That's pretty convenient to see something that no human being has seen in recorded history. So, mark your calendar at the beginning of August to see Mars grow progressively brighter and brighter throughout the month. Share this with your children and grandchildren. NO ONE ALIVE TODAY WILL EVER SEE THIS AGAIN? Нещо интересно изпратено ми от мой познат - хамлет - 07-27-2006 The Red Planet is about to be spectacular! This month and next, Earth is catching up with Mars in an encounter that will culminate in the closest approach between the two planets in recorded history. The next time Mars may come this close is in 2287. Due to the way Jupiter's gravity tugs on Mars and perturbs its orbit, astronomers can only be certain that Mars has not come this close to Earth in the Last 5,000 years, but it may be as long as 60,000 years before it happens again. The encounter will culminate on August 27th when Mars comes to within 34,649,589 miles of Earth and will be (next to the moon) the brightest object in the night sky. It will attain a magnitude of -2.9 and will appear 25.11 arc seconds wide. At a modest 75-power magnification Mars will look as large as the full moon to the naked eye. Mars will be easy to spot. At the beginning of August it will rise in the east at 10p.m. and reach its azimuth at about 3 a.m. By the end of August when the two planets are closest, Mars will rise at nightfall and reach its highest point in the sky at 12:30a.m. That's pretty convenient to see something that no human being has seen in recorded history. So, mark your calendar at the beginning of August to see Mars grow progressively brighter and brighter throughout the month. Share this with your children and grandchildren. NO ONE ALIVE TODAY WILL EVER SEE THIS AGAIN? - s0me0ne - 07-27-2006 Дали ще се вижда от България? В колко часа? На 27 август ли? - s0me0ne - 07-27-2006 Дали ще се вижда от България? В колко часа? На 27 август ли? - хамлет - 07-27-2006 Ами моя познат е в Калифорния значи някъде 11-12 часа е разликата ако не ме лъже паметта - хамлет - 07-27-2006 Ами моя познат е в Калифорния значи някъде 11-12 часа е разликата ако не ме лъже паметта - miro343 - 07-27-2006 я пояснете ,че навремето учих немски МАЙ - miro343 - 07-27-2006 я пояснете ,че навремето учих немски МАЙ - хамлет - 07-27-2006 Ами в общи линии се съобщава че този и до края на другия месец Марс (планетата) ще е най-близко до Земята като за последен път това е било наблюдавано предполагаемо перди около 5000г., а се очаква евентуално следващото приближаване да е през 2287 като някво влияние на Юпитер имало сега и май май в следващите 60 000г няма да има подобен феномен, поне набързо като му хвърлях поглед това разбрах, а датата на "срещата" е 27 Август т.г., но най-добре е ако имате познат който се занимава/л с Астрономия или посещава курсове там доста подробни сведения имат като цяло. - хамлет - 07-27-2006 Ами в общи линии се съобщава че този и до края на другия месец Марс (планетата) ще е най-близко до Земята като за последен път това е било наблюдавано предполагаемо перди около 5000г., а се очаква евентуално следващото приближаване да е през 2287 като някво влияние на Юпитер имало сега и май май в следващите 60 000г няма да има подобен феномен, поне набързо като му хвърлях поглед това разбрах, а датата на "срещата" е 27 Август т.г., но най-добре е ако имате познат който се занимава/л с Астрономия или посещава курсове там доста подробни сведения имат като цяло. |
