Threads: 25
Трябва да нямаш COM 1 на компютъра и после така:
If you need to change the COM port that the virtual serial port was assigned, you can do so by using the device manager in Windows XP. This can be accessed by:
Going to Control Panel->System click the Hardware tab and select Device Manager
There is a windows key shortcut for getting to the System menu it is: Windows Key+Puse/Break key
Right click on My Computer and select Manage. This will bring up the Computer Management interface which should have the Device Manager
Expand the Ports item and find the COM port you want to adjust, FTDI com ports are typically USB Serial Port(COMXX). Right click and select properties, go to the Port Settings tab, and click Advanced.
There should be a drop down box for the COM port, you can change the assigned COM port by selecting from the menu. Note, if a COM number is already in use you should not try to assign multiple devices to the COM port. If you have run out of lower COM ports (for older applications that can't access all COM ports) then you will have to unplug some of the other COM ports. You can also deactivate the secondary COM ports on FT2232C devices if you don't need them or assign them to higher COM ports to free up the lower ones.
Volvo V40 1997, 2.0
Threads: 100
3
Някой да си е купувал китайски клонинг на DiCE?
Събирам мнения и препоръки, пък ако не - действам през глава...
Threads: 25
Второто мнение в този пост е, че работи, но не поддържа всички функции на VIDA.
<!-- m --><a class="postlink" href="http://www.volvo-forums.com/t33504-volvo-dice-from-china.htm">http://www.volvo-forums.com/t33504-volv ... -china.htm</a><!-- m -->
Volvo V40 1997, 2.0
Threads: 32
joro74 Wrote:Трябва да нямаш COM 1 на компютъра и после така:
... Това с този XP доста усложнява нещата. Дали би станало с Live XP бутнат от флашка? Не ми се съсипва седмицата за да пусна XP.
Николай
Volvo XC90 2.4D '2008
Threads: 100
3
joro74 Wrote:Второто мнение в този пост е, че работи, но не поддържа всички функции на VIDA.
<!-- m --><a class="postlink" href="http://www.volvo-forums.com/t33504-volvo-dice-from-china.htm">http://www.volvo-forums.com/t33504-volv ... -china.htm</a><!-- m --> Това го четох, но е от типа "чувал съм че..." при това е от 2010-а, а сегашните китайски клонинги са малко прецизирани, точно от този феедбек - "не могат да качват софт на колата" - еми като не можеш да го купиш как ще го качиш ...
Питам за човек, който наистина има и си е играл с него.
Threads: 100
3
Zahariev Wrote:joro74 Wrote:Трябва да нямаш COM 1 на компютъра и после така:
... Това с този XP доста усложнява нещата. Дали би станало с Live XP бутнат от флашка? Не ми се съсипва седмицата за да пусна XP. Пробвай с дуалбуут на нормално XP. Лайф ОС-та са орязани и са правени всяко за определени цели - едно за чистене на вируси + "ремонтиране" на машината, друго за администратори да си бутнат нещо без да мъкнат цяла машина, трети за определени машини - питай чичо гуугъл за Asus EEEPC колко енлайтнати XP-та има ...
Защо - защото не се знае какъв какъв Лайф ще случиш - може да е орязан именно откъм комове. То принципно за какво са ти (не на теб сега де), аз бих ги орязал също...
Threads: 25
За всеки Windows си е същото, няма значение XP, Vista, 7,8. Просто даваш 'properties' на 'USB com port X' и в таб Advanced си сменяш порта.
Volvo V40 1997, 2.0
Threads: 32
joro74 Wrote:За всеки Windows си е същото, няма значение XP, Vista, 7,8. Просто даваш 'properties' на 'USB com port X' и в таб Advanced си сменяш порта. Идеята за XP беше, че кабела работи само под тази ОС.. В крайна сметка някой подкарвал ли е под Windows 7?
Николай
Threads: 25
Кабела използва чип на FTDI за емулация на Com порт през USB. Просто нямаш драйвери за Win 7, можеш да ги свалиш оттук <!-- m --><a class="postlink" href="http://www.ftdichip.com/Drivers/D2XX.htm">http://www.ftdichip.com/Drivers/D2XX.htm</a><!-- m -->
Volvo V40 1997, 2.0
Threads: 0
аз се намирам в Германия и от вчера имам Волво S40 1.8i 2004. Интересувам се какъв софтуер е съвместим за диагностика на моята колица? До колкото видях в книжката е с ОБД2 кабел така, че се интересувам от софтуер-а.
Благодаря предварително!
