menbru са незабравимо нов тук от скоро се преместих в София, аз искам да помогна на някой, който има любовник Volvo 760 от 1988 г. Имам нужда от задната ос, можете да закачите снимка, песента може да бъде дузпа, avati идея Как може ли да получа тази песен и къде?
salutare sunt un menbru nou aici pe la voi de curand m-am mutat la sofia , vreau sa ajut un iubitor de volvo ce are un 760 din 1988 imi trebuie Rear Axle , voi atasa si o poza , piesa poate sa fie SH , avati idee cum as putea face rost de aceasta piesa si de unde?
menbru are greeting a new here from you soon I moved to Sofia, I want to help a lover who has a Volvo 760 in 1988 I should Rear Axle, you attach a picture, the song can be SH, avati idea how could I get this song and where?
VOLVO FOR LIFE
PHONE : 00359 87 87 15 024 ( spek english, romanian, litel bulgarian)
0040 727 258 120 ( romanian)
SOFIA -LIULIN
<!-- m --><a class="postlink" href="http://avaleriu2000.webs.com">http://avaleriu2000.webs.com</a><!-- m -->
Are you offering these parts, or you need them? It is not clear from crappy google translation..
Try again buddy! This time in english or russian Then may be someone will be able to help you..
Sunteţi care oferă aceste părţi, sau aveţi nevoie de ele? Nu este clar de la google traducere nasol ..
Încercaţi din nou amice! De data asta în engleză sau rusă Atunci poate fi cineva va fi capabil să vă ajute să ..
ipdown Wrote:Are you offering these parts, or you need them? It is not clear from crappy google translation..
i need these parts
VOLVO FOR LIFE
SOFIA -LIULIN
i need these parts
VOLVO FOR LIFE
SOFIA -LIULIN
Do you have a solid rear axle or multi-link (one with independent rear suspension)?
Post your VIN number (the chassis number, should start with YVxx..), so that we can check it for sure.
I am pretty sure, someone here will have some parts left out.
You can probably go to Moto-Phohe or ScanTech, but that would be quite expensive.
Another option that looks more promising is checking at some junk yard, any from 740/760 or 940
with the same gearbox should match.
Oh, and also, do you own a wagon or sedan?
Колегата от Румъния търси заден мост за 760-та си. Проблема е че не можем да се разберем още.
Английския му е зле, а румънски не знам Опитвам се да разбера какво точно търси за да се опитаме да му помогнем.
Питал съм го за точния модел и дали е с независимо окачване или цял мост..
Човека е в София, така че като се изясни какво точно търси, може би някой от вас ще може да му помогне.
Със сигурност е 760 седан, с независимо окачване и предполагам, че е Мултилинк 1, но нямам идея откъде може да намери тези полуоски, освен от някоя морга, както си го посъветвал и ти. Не знам точно, в какво се изразява разликата между Мултилинк 1 и Мултилинк 2, но ако има разлика в полуоските, то трябва да внимава, да не напипа полуоски от някое по-ново 960 и да не му станат. А ако проблемът му е само в каретата, то по-добре да си ги купи нови от Скантех.
