02-12-2013, 09:07 PM
1. Engage the auto-down function and remove fuse 11C/5 (for driver's side) or 11C/4 (for passenger side) (located in the driver's side dash fusebox) during window movement.
2. Install fuse back into position.
3. Engage the auto-up function and hold it engaged for 5 seconds after the window has reached the fully closed position.
4. Verify window is now working properly.
5. If this procedure does not work, a scan tool that can access the Passenger Door Module (PDM) and Drivers Door Module (DDM) will be needed.
Изнамерих това.
Изнамерих това.
